** EK Watercooling Kits - Watercooling in a Box! INTEL AND AMD **
don't think it would fit, well not without some serious modding.
check the dimensions of the rad on EKs website would be my advice.
always wanted to give WC a go but always looked complicated and a bit too much £££ out of my wallet for my liking but these kits look ideal for beginners and so cheap as well :eek: +1
My understanding went as far as needing a cpu block, some tubes and some fluid. It's all the various connectors and fittings that left me stumped.
Exactly this, and I don't have time to research.
If I were to get this, it would help my understanding a LOT and then I might continue my watercooling adventures and get higher end stuff on my own.
Now just to find the money... :(
that is a very good point, the main factor that most customers omit is the research involved in watercooling. Our sales team ask me to spec custom loops for customers often and this is because they find the spectrum of components confusing themselves. with kits like this, you are getting quality, standardised fittings. I always say that the best way to learn something is by doing it yourself, these kits practically walk you through it step by step. you also get the added bonus of being able to upgrade things in the kit easily.
if you wanted coloured tubing, you could buy that, if you wanted to add more premium fittings such as Bitspower, you could. it gives immense scope for customisation which is always a bonus to any enthusiast in my eyes :)
Our original allocation is selling out fast on pre orders so be sure to get orders in quickly.
think i will treat myself to one of these kits for my bday next month but not sure how much of an improvement it will be over the H100 and also i have been looking at the frozenQ Liquid Fusion V Series 240mm Reservoir (T virus) but not sure it will be compatible with one of these kits as i am a complete noob when it comes to WC :confused:
the T-Virus res would be compatible with this kit. you just omit the EK res included. you would need some extra fittings to include it.
i would suggest one of the HF kits if you plan on using that res as the pump is a lot better.
thats good to know :)
i probably would have just gone with the H100 if the T-virus res wouldn't fit
thanks for the intel ;)
spoke too soon. stock arrived this afternoon.
all pre orders have shipped and the remaining stock is up for grabs!
not really sure what's happened there. apologies for the delay.
will keep an eye on your order and ensure it ships today without fail :)
This is great news,Ive been wanting to dabble with Watercooling for a while now but lack of knowledge with knowing all what bits i need and the high cost of buying parts individualy put me off.
Id be very tempted to get one of these for my next build. :)
If only these were available when I watercooled my machine way back in 2009. Since then, I have disposed of all the kit I had. GPU is no longer watercooled. The CPU now uses a Corsair H50. And that's about it.
But yeah, even I remember picking out the fittings and boy did I get stumped a number of times trying to get the right ones. Even OcUK sent me the wrong ones a number of times :p Ah good times tho and a very good experience but never again. Well at least not right now anyway ;)
These look like a really great way to start watercooling and EK stuff is top notch. I wish they had been available when I started :(
