Caporegime
- 8 Jan 2004
- Rutland
Well, if you bagged one of these for £220 then I'd say you've done pretty well by the sounds of it![]()
I did indeed. Tempted to buy a proper colour calibrator now.
Well mines up and running. Really impressed.
No back light bleed, uniformity of backlight is great until the last couple of mms each side which look pretty dim.
Colours I've not quite got right yet. Used the above settings but found changing the colour effect to movie crushes the blacks badly, feels like dynamic contrast is enabled when you select that.
The side 1/4s of the screen have a reddish tinge to them on an all white screen, will see if I can tweak that away. That's the only downside so far. I don't think I'll be doing photo editing on it, but great for gaming.
Running at 85hz happily.
(stop gap till AMD release somat kick ass)
I fancy one of these to replace my naff 4k screen thats gone bang but a bit cringey at 300 when they were so cheap before lol
As the other place comments have also experienced this issue, I would avoid this monitor. Returning because of the below.
Mines the same, not sure whether to send it back or not. Are you going for a refund or a replacement?
Seems a shame to send it back for a refund because it’s liveable with and the rest of the specs 100hz/res and size are amazing for the price. But I can’t use it for photo work so will end up running it side by side with my U2515H which I was hoping to sell.
I'm going for a refund. I can see the blotches on other colour backgrounds too which is annoying.
I think I will decide on a large 2560x1080 ultrawide. The 34" native resolution, text was a little to small for my eyes.
You sure? 1080p 34" is a bit too pixelly, I'd keep it around 94ppi.
Try 29" 1080p UW
