im no expert at monitors and even worse at writing things down and explaining. what do you want to know i can try explain that?I
Review of this monitor mate?![]()
I just bought the monitor from laptopsdirect after reading all the posts here and I'm really happy about it !
It just arrived today, I'm testing it right now but I can't manage to change the refresh rate. I tried with AMD Radeon settings and it says "The custom resolution settings are not compatible with this display. Reconfigure your settings and try again"
So I tried with CRU, and when I apply the new custom refresh rate (100hz) the screen goes black. Same for 75hz. Tried with two different HDMI cables.
Monitor is cool but I would really like to get my +100fps in game :/
I'll buy one on Amazon, thanks for the help !Try a decent displayport cable.
I tried again with a DP cable, and it's working ! I can go up to 120Hz ! It might be able to go higher but I don't think it's a good idea to keep going, the bottom of the monitor is already really hot and it's a refurbished one.Try a decent displayport cable.
Fantastic! You see a big difference in terms of smoothness?I tried again with a DP cable, and it's working ! I can go up to 120Hz ! It might be able to go higher but I don't think it's a good idea to keep going, the bottom of the monitor is already really hot and it's a refurbished one.
But thanks again !
This. It doesn't help anyone using exclamation marks on each sentence. While waiting on Laptopsdirect, if your monitor is overclocked, try returning it to stock settings.Ok, what you're supposed to do is CALM DOWN, contact laptops direct and arrange for an RMA. Then insist on a replacement, not a repair.
