Ok here are the settings options on my version of the monitor:
Brightness/Contrast menu:
brightness
contrast
DCR
HDMI/Mode
Color Setting menu:
Gamma,
picture mode
color temperature
USER
Low Blue Light
Hue/saturation
Picture Quality Setting menu:
Bypass
Sharpness
Response Time
Uniformity Compensation
Dynamic Luminous Crontrol
FreeSync(Adaptive Scan)
Display menu:
Aspect Ratio
DP version
Other menus that i wont go into:
Audio
Multi-window
other
What is DCR for?
The color temperature has 3 options: Normal, Warm and Cool. Which one is 6500k? or how do I find out?
What is Bypass for?
I am surprised about the Response Time option, it has 3 settings low, standard and high. Why have this menu, surly the fastest one is the best? what should i set it to?
what is Uniformity Compensation for?
what is Dynamic Luminous Crontrol?
As you can see no overdrive of obvious way to increase the hz?
I have tried calibrating the monitor using a spyder 5 express. It has'nt made much of a difference but it is tuned to work on 6500k and i am not sure what color temp that is. The standard setting looks a but blue to me.
brightness
contrast
DCR
HDMI/Mode
Color Setting menu:
Gamma,
picture mode
color temperature
USER
Low Blue Light
Hue/saturation
Bypass
Sharpness
Response Time
Display menu:
Aspect Ratio
DP version
Audio
Multi-window
other
What is DCR for?
What is Bypass for?
