S/C setup will cost me a lot more than the hairdryer though, will it not?
what about grip? have you considered how hard it will be to drive when under boost? LSD would help, but still a lot of power through a very light front end.
You posted "Jackson with no intercooler isnt really that great for sustained use" but nobody suggested running anything without an IC so I'm confused as to why you even brought it up :/Me. I think that comment was in my post![]()
Prelude isnt that strong, Nikasil bores and revvy pistons. 2.3 is far better to boost, or even the F20B 2.0
N/A because more than 250bhp through FWD is compleatly pointless
Is it okay if I post again?.
No you are only allowed to suggest bodged up ideas that involve baked bean cans and pieces of string. Oh and the car must be on wheels that have had hairspray sprayed inside them
TBH I dont know what your going to be using the car for though so its hard to select without that information.
To play devil's advocate for a second, why are you constantly chasing the Jones'?
Personally, I'd prefer to have a mildly tuned car that was running PERFECTLY, than have a mad car that was dodgy. I'd take more pride in that.
) Scrabbling for traction is not really any different to waiting until you get to 10,000,000 rpm and hit VTEC y0! now to go is it?
