In other news..
My S3XY Knob and buttons turned up yesterday (had to pay VAT which delayed it by a day!)..
(stock image)
Installation 6/10
- Surprisingly little information, I had to find videos and read between the lines to install it.. 4/10.. I did find an installation guide on their website, but it only shows a rear installation and I decided to follow other peoples guides on installing it in the front since the rear installation leaves the commander loose and on show..
- Ease of install with the right information - 7/10
- What all the videos don't say is that the middle and lower A Panel trim pieces you have to remove in the RHD models have these small plastic edge clips that don't all come away with the trim.. queue me losing 2 as they fall in into the void underneath!.. I'm going to guess people are happy to just slap the trim back on without all the clips properly holding it in..
- Those little white edge clips are not easy to get hold of, they aren't part numbered on the parts catalog but Tesla apparently will sell you some for nearly £7 each! I think I've found some clones (
https://www.ebay.co.uk/itm/134788324440) so have ordered 40!
- The actual 'knob' part is a breeze to fit, just one USB-C and clip it in.. they provide stickers to fine tune any minor height differences in trim.
- The colour match isn't perfect on my late 2023 Model Y but close enough.
Setup - 9/10
- A breeze, just launch the app and click on the controller and it will find it within seconds.. Same for the knob..
- both had firmware updates pending which took 2 mins.. although I had to close/re-open the app because the app did not recognise the knob had rebooted post firmware so was stuck looking for it.
- Adding 2 buttons (one on each rear door behind the windows switch) was super easy..
Functionality - 7/10
- Oddly even though the primary interface of the knob is the 4 buttons, you get less choices to configure them then the regular s3xy buttons.. you'd think they would have all the same actions, in fact more for the knob due to the button and rotary interface.
- You can set each 'action' so you either press a side button, then use the wheel to select between enabled/disabled etc, or you can say 'auto action' which means just pressing the button will toggle the action which is nice..
- Oddly the display shows you what each button is for, but if you take drive mode as an example, I have it so pressing a side button toggles between 'chill' and 'standard'.. however when on the main display showing the 4 icons for each button the icon on that button does not show the state of the drive mode, it would be good if it had some subtext or colour or something to denote the state (e.g. blue icon for chill, red for standard etc)..
- There are far too many actions that are not synchronised with the main Tesla UI.. so turning on heated seats for example does not show on the main UI. this is a Tesla interface issue and actually shows (IMO) a very poor architecture decision (I have a lot of experience in this kind of thing!).. However, some do (such as wipers)..
- I like system wide functions like 'Thank you' which flashes your hazards three times for rewarding considerate drivers.. Or using the rear passenger door handle to allow the charge port to be unlocked.. I've yet to try the auto-pilot re-engagement but have a 300 mile trip to do tomorrow so will get some miles on it.
- The s3xy buttons (I ordered 2 with the knob) are good, as I said I mounted one on each rear door arm rest behind the window switch and have it so a single click toggles the heated seat on that side, double press turns the rear fan/vent on/off and a long press will put the fan speed on Max, so passengers in the back don't need to ask someone to do that for them.
- Overall though, the number of functions/actions I need are fairly limited.. I have the 'thankyou' , 'autopilot toggle', 'acceleration mode', 'mirror fold' with 'wipers' as the main knob function and then just simple stuff for the passenger 'glovebox', 'voice control', etc.. things that are a faff through the main UI..
Overall 6.5 - 7.0 / 10.
I'll see if I can send some suggestions based on my initial experience, I found the guy who did the UI have this in his Bio, but honestly I would not be that proud of such a blind interface, it's a bit style over functionality IMO, it needs to have the least transactions with status information conveyed at a glance.. minor but it needs that polish.
It is another nod that Tesla is like Apple.. they only make a few items and decide on how you interact/use it which can be frustrating, but the aftermarket accessories market is huge and you get a lot of cool things!
