- 4 Aug 2007
- Wilds of suffolk
Is that USB plug on the side of the AMI to scale?
for ioniq hybrid, couldn't see any threads where people tried to corroborate the 30mile ev claim,
I guess you can't disable ICE intervention completely, which makes me more suspicious of whether the tax thresholds are really satisfied.
https://www.ioniqforum.com/threads/in-hybrid-how-far-could-you-travel-in-ev.30506/ people just talk about 4-5 miles in pure ev
suggest some data then ? - didn't know ioniq had a mild version, 7.1kwh usable was their hybrid option no ?
which is what I said, and linked; but can't see any data where people confirmed 30(40!) miles
a, pinch of salt data point; so, getting to work on a cold day might be problematic.The EPA rates the plug-in Ioniq as having 29 miles of EV range, although during steady 75-mph cruising on the highway our test car went just 18 miles before the engine fired.
ok the first link was plugin hybrid and the second inconsistantly (mild) hybrid, strange those forum folks have not benchmarked plugin range
I'm sure there is some gain - however I think 10% is an optimistic figure.
subsequently - saw a thread on the ioniq phev ranges https://www.ioniqforum.com/threads/phev-hitting-40-miles-on-ev.29784/You like real people data, so though you might be interested in this thread HERE! about a Golf GTE PHEV.
Yes the GTE wheel change is interesting ...can't see if the 16"'s are narrower than the 18's (look at i3 tyres), or its a rolling resistance/aero gain. (I use GY efficient grips)
but the tesla model 3 aero wheels too, it's an option -no ? , are arguably less attractive
edit 225->205 ...not 'much'
Old: Serron 18" 7.5J - ContiSportContact 5 225/40 R18
New: Astana 16" 6.5J - GoodYear EfficientGrip Performance 205/55 R16
25% difference now? Unfortunately, any data is skewed by a natural bias. It's all down to how he drives it now that he's invested in those ugly wheels.The user has already demonstrated that it was over 10%.
Down from 20+ kWh/100km to as low as 14.5kWh/100km.
I think it's more down to not having a driveway than the 'hassle' of plugging it in.40 miles of range would cover the vast majority of daily commutes with range to spare, it's just that for most people getting into the habit of charging the car daily, or bothering to actually have a charger installed is an issue in itself.
Tyre pressure would have a bigger effect. It's pretty easy to reduce your rolling resistance by upping the pressure. I used to run my old Insight at 50psi. That rolled pretty easily.I doubt the size makes such a big deal, more so moving from a sports tyre where rolling resistance is not very good to an eco tyre where it is.
I would just put Eco based tyres on 18s, if you want to save weight you can buy lighter 18s
