Say that again when it snowsFwd EVs shouldn’t be allowed tbh. And a 134hp Vauxhall. Not the best intro to EV world
I doubt it regarding the grip in snow, i drove past plenty rear wheel drive cars that were stuck a couple of year ago.Even less grip when it snows then? He’ll probably say exactly the same.
This sounds more like you don’t know how to drive more than anything else.proof of life photo V well I lived after driving it.
yes the power and torque is impressive, with some torque steer/traction control evident if exited roundabout fast (not really via steering wheel but backside) but it's fwd, too.
brakes are biggest issue not progressive, seemed on and off, so that you couldn't modulate bend/roundabout approach speed by feeling what kind of momentum/deceleration you created
'otherwise' weight wan't too evident could feel some chassis movement side to side on uneven fens roads that suspension wasn't able to quell & it rather fell into potholes
... several days to try it out now.
yes but ev's have a more uniform weight distribution with heavy battery, motors can (agree - should) be in the back so you can use that for rwd traction benefit - so do the rules of fwd still hold.Say that again when it snows
Just because a car has xx bhp it doesn't mean it has to be used.
I’m surprised the first comment was impressive power in the context of a 134hp heavy car really. It must feel weak even compared to a 200hp rwd EV. But hey. After 3yrs of reading links and seeing videos, to make his opinions, he has finally got behind the wheel of one
Is it pure regen initially, or blended (supposedly taycans prowess), either way there's no progressive aspect, and it feels as though they have been over cautious trying to anticipate mokkas weight,Yes the regen braking takes a little getting used to, but come on.
I’ve no idea whether it’s ’blended’ or not, but after 30 minutes driving the car I experienced none of the supposed issues you had.Is it pure regen initially, or blended (supposedly taycans prowess), either way there's no progressive aspect, and it feels as though they have been over cautious trying to anticipate mokkas weight,
even though only 1600kg(I just learned)
but it wouldn't be fun for passengers or the guy in car behind
e: ??? can regen braking alone be progressive ? you don't have a clutch in the drivetrain do you ?
I'm not sure if my e2008 is a relative of the Mokka but I had the same feedback on e2008 brakes. It was like they were either on, or off. Very difficult to impart good driving wisdom to my wife when the car behaves pretty poorly.Is it pure regen initially, or blended (supposedly taycans prowess), either way there's no progressive aspect, and it feels as though they have been over cautious trying to anticipate mokkas weight,
What are you talking about/to?Maybe read the manual? Check setting for B-mode.![]()
as dlockers clarified , I am being unclear I mean when you are using the brake pedal, how much of that energy is dissipated in regen versus friction brakes, and,And yes, regen braking can be progressive in the sense that the more you come off the accelerator the more regen you get.
wondering if the regen brakeing, which I suspect is prioritized, is less progressive than friction (where I would say I can usually scrub off the speed I want, without jerkiness)
as dlockers said I thought B-mode was just for regen/coasting/lift-off , but need to play with it.
e: no video ? I had read this, out of interest before replying, which is way beyond any video or desciption I'd seen before
https://www.theautopian.com/why-an-...-why-you-shouldnt-be-scared-of-brake-by-wire/
E2008 and apparently a Mokka. Driven either of those?I've never driven an EV that has jerky brakes.
