- 22 Mar 2004
The Indra Smart Pro got installed today. Talk to me about energy tariffs, is there an out and out winner or do I just stick Charge Anytime onto my OVO account?
Drove in one pedal mode for the first time today. Certainly a different experience, only had to use the brake a couple of times. Seems to have saved a bit off my journey and not all that problematic to use.
Once you get used to it it becomes second nature to use it. We've had it on the last 3 EVs and you get much more used to using the throttle as a speed regulator rather than a go faster pedal and letting the car regen when slowing is just a case of reducing the throttle input to control the retardation amount. Now i've had it its strange driving the car and having to use the brake pedal. Takes a second to remember when the battery is > 90% full and regen quantity is reduced on the iPace until its got somewhere to put the recovered power.Drove in one pedal mode for the first time today. Certainly a different experience, only had to use the brake a couple of times. Seems to have saved a bit off my journey and not all that problematic to use.
I hate not being able to lift my feet off the pedal and coast so I always go min regen
On all cars apart from Teslas the braking is regen to start with anyway so there should be zero (or positive as you can now coast without regen) efficiency impact
Mercedes have a good system where you can change the lift-off regen using the ‘gear change’ paddles on the steering wheel.
Really? No in my carSame with MEB.
Yeah paddles would be ok, but in the meantime just set it to minimal and use my footMercedes have a good system where you can change the lift-off regen using the ‘gear change’ paddles on the steering wheel. From full to nothing (coast6 you can control your speed going down hills without having to move your feet!
I do think one pedal is a good way to get passengers car sick.
on the motorway i just use cruise control........ if i get some empty road and want to have a play it does not stop me giving it some welly but to be honest motorways are not the place to have an engaging fun drive anyway so usually just set the car to (indicated) 74mph and leave it too it.I just hate the idea of my foot slipping off the throttle at 70mph on the motorway…
The Ipace max regen mode definitely has this effectI do think one pedal is a good way to get passengers car sick.
