It’s bigger than a polestar 2!
Really? Doesn't seem that way in pictures. Looks small. Not watched a review of it or looked at specs tbf.
You have one?
Would you risk it on an older Tesla or I Pace, or any other recommendations?
Vw's are banned from military sites as well as jlrID.3 is a bit on the small side for a family car i think. Plus isn't much of a looker (subjective i know) and on top I think it was on a list published of cars to avoid due to possible Chinese spyware.
In what world is a model 3 not a ‘large family car’?Why is it. They are pretty small in the back with the low roof line
Have some significant miles in a model 3. Id3 and CUPRA born is significantly bigger. With much more rear headroom. They are also better cars (but worse computers with wheels) and the seating position is far more comfortable as you aren’t lying down. I’m 6’3 and 105kg if that makes a difference ?In what world is a model 3 not a ‘large family car’?
I’m not sure I’d consider a model 3 to be ‘small in the back’ either.
I’m 6ft tall and there is more than enough space for me (leg and headroom) and 2 adults in the back fit more than comfortably.
3 adults isn’t going to happen for more than a quick trip round the block but few cars will seat 3 adults in the back comfortably.
It dwarfs the likes of a polestar 2 for interior space and you can pick up long range dual motor cars for the bottom end of the budget in decent condition. They also have more range and charge faster than Polestar 2’s at this price point.
@tres Model 3’s are generally reliable. The weak points are the suspension (both firm and wears quickly) but it’s cheap to repair if needed. Good 3rd party parts are available and no need to take it to Tesla for that kind of work. If you are looking at a pre-2021 car with the silver trim, check the pain around the sills and the inside of the arches carefully. Supercharger network is ‘cheap’(er), easy to use and reliable, of course you have all other public chargers to use also.
Yes it’s a sample of 1 but these cars have proven they can do the miles over and over:
The other obvious issue is Musk and the extreme ‘anti-Musk’ crowd but even that seems to be blowing over as quickly as it started.
Compact saloon? No, not really. Sure, it’s only 4.7m but it dwarfs the likes of a 3 series in terms of interior space, ground up EV and all that. It’s much closer to a 5 series in terms of the interior space but as like many EVs, with a smaller height between the floor and top of the rear seat base due to the battery - just like other ‘non-SUV’ EVs.Id3 and CUPRA born is significantly bigger. With much more rear headroom.
Polestar2 are also tiny in the back seats so not sure why that’s a reference
A model 3 isn’t a large family car. It’s a compact saloon at best.
mg5 vs 3 touring for usable boot space the mg5 wins.family car is something with practicality of interior space to put the proverbial kitchen sink in, or moreover trip to diy store, ******* big television, washing machine,bicycles,
used to put 3 people and bicycles inside a vectra hatchback - 3 touring and A4 avant have improved on that,
respective volume of the batteries beneath floor, versus the ICE accouterments beyond it's wheelbase, isn't favourable for ev, so have to build vertically;
Alpine with batteries at front and back will be an interesting ev evolution.
really? why is that?Vw's are banned from military sites as well as jlr
The opposite of French fries.really? why is that?
What's a3 touring?But we were comparing a id3 to a model 3. Not a 3 series. Id3 or cupra is much bigger and a better family car in my experience
11cm taller can’t be ignored
Peeple keep banging on about this banned from military sites stuff but why would that stop you buying a car unless you're in the military lol
Is this the same MOD that uses tiktokIf they have been banned by the MOD it means GCHQ has most likely found something suspicious. It's only a matter of time before someone else hacks their way in as the CCP doesn't really care about the security of it's victims.
Not sure what you mean. I was lazy and had error that didn’t quote but wasn’t replying to you. Somehow a bmw 3 series got into conversation about EVsWhat's a3 touring?
That's the part I assumed was a3 series touring.
