- 24 Mar 2011
- Cambridgeshire
That’s a big IF and is unlikely to be the case.
Pretty much all EVs slow down to a lesser or greater extent as the SOC (voltage) drops.
They do, but not many start dropping power as soon as your away from 100% SoC though. That is a pretty notable deficiency.
If it had 1000 kW output then sure, but anything with 200-350 kW output with a reasonably sized battery should still be able to do near full output down to around 50% SoC at least, assuming it's warm conditions. To drop power at a linear level means it's current limited, and that only happens if they're running undersized power cables from the battery, or don't have a big enough 3 phase inverter for the motor to handle the increased input current as SoC decreases. Both of those are not good, but it how you get cheap power I suppose.
Its like a 70s Italian car.
