- 17 Mar 2004
how much was said tv?
never bought a tv from argos never will after reading this ,to claim it was caused by handling the tv is just BS what was you supposed to do levitate the tv into the shop . hope you get it sorted
Why as others have said you need to have a certain number of dead pixels or a cluster for them to replace under warranty. It's not the managers fault it's the guidelines set by the manufacturer.
Op seems to be ignoring the fact that there are not enough dead pixels to be considered faulty anyway?
Surely it depends on if a pixel is dead or stuck.
A stuck green one in the centre of the TV is a lot worse than a dead black pixel.
it not faulty- problem solved
Dead Pixel not exceeding 7 dots is within factory specification and is not considered a defect under this warranty
DOES NOT COVER MINOR IMPERFECTIONS IN PRODUCTS THAT MEET DESIGN SPECIFICATIONS OR IMPERFECTIONS THAT DO NOT MATERIALLY ALTER FUNCTIONALITY. WE MAKE NO SATISFACTION GUARANTEES, PERFORMANCE GUARANTEES
caps from the website cba to retype but HTH
TV from Argos
Rest of the story?
Obviously I carried the TV into the store so there was a couple of finger marks on the display but thats it. He pointed them out and I said they were from carrying the TV.
I tried explaining about dead pixels etc but he wouldnt replace it and claimed it was my wrong doing.
Hahaha.
But in all seriousness, is there anything that can be done? Dont like the idea of having the faulty TV.
