Mate don't explain yourself,And regarding the PSU it's not the best,Personally Id try and get hold of a corsair vx550w.
It just annoyed me that's all, so I just thought i would explain how ive not got £800 at my disposal for a gaming build.
I no mate and i understand that,So what parts do you have now and what are you planning to get?
A Q6600 is a great chip, quad core and a fat 8MB cache, get it O/C close to 3ghz and your sorted.
E8200, 6MB cache, 2.66ghz.
Check the cpu support list of your motherboard to see what it can take.
found these
Intel Core 2 Quad Q6600 2.4GHz 8mb cache
Corsair A50 cpu cooler
It seems their are several revisions of your MB so you will need to check which you have against this list.
http://uk.asus.com/Motherboards/Intel_Socket_775/P5KPLAM_EPU/#CPUS
before you purchase one that might not work.
Also you may need to update the bios accordingly.
Thats a great CPU if its in budget, What's the cooler you posted a picture of? if it works and its 775 then I don't see any reason why you would need to buy another.
Save your money for something else.
found these
My mother board is -am epu and i checked the list for the correct one and that is on the cpu list on the asus website.
I meant on that list it shows under "Since PCB" 1.01/1.02 /All, so a q6600 will only work on a revision 1.01 or 1.02 not a 1.00 if that makes sense.
Not sure what that cooler is tbh, maybe someone else can shed some light on it, are you going to be overclocking? if not a stock intel cooler will be just fine, and can be had very cheap if you don't get one with your new cpu.
If you can get a Q6600 for a reasonable price you will be more than happy i assure you![]()
Maybe abit of overclocking if i could get some help with it
How do i find out the revision for the board?? i have??
So good news on the CPU front and you should get it if you can, as I mentioned above. If you don't know/not sure on how to flash your BIOS to the latest version, let us know and we can guide you through the steps when you get that far.
His board will support the q6600 and will work straight away, but a BIOS update may be necessary to ensure maximum stability. The PCB revision number should be somewhere on the board, but I cannot glance it from the photos myself. It will suffice to say that it is most definitely not v 1.00 - that had only two SATA ports and had a different component layout. It also didn't support the FSB speed of 1066 Mhz, which Luke's board clearly does!So good news on the CPU front and you should get it if you can, as I mentioned above. If you don't know/not sure on how to flash your BIOS to the latest version, let us know and we can guide you through the steps when you get that far.
The GPU you found is also good on a budget, and it will do more than play your games. The NVIDIA 8800GT 512MB with 112 shaders is also worth considering for around 20-30 quid. There are also better variants in the 8800/9800 line about, so if in doubt, just ask.
Oh, and here are some reliable PSU brands to keep an eye out for: Corsair, Tagan, BeQuiet, Enermax, Seasonic and OCZ; Coolermaster is also serviceable and will do the job just fine, but see if you can do better first, as you did with your PSU choice. It does not hurt to shop around!
If you can get a reputable unit in the 500W - 650W range, which is under or slightly over a year old in terms of use, that would be ideal. Don't hesitate to post any options you may be considering, too.
Finally, never mind the trolls! Haha, unfortunately they are about on these forums, but the ratio of genuine and helpful folk is vastly superior to their number. They don't know what they are talking about, so don't feel like you have to justify yourself to them.![]()
