FIRST BUILD HELP!? - BEST GAMING PC FOR AROUND £2500
Glad it was something simple
And for future reference
Yes you would just touch both pins with a
Screwdriver
As pwr is a momentary switch it doesn't need to be continuously held on the pins
Just a fraction of a second to complete
The circuit
In such a case, you should consider that without auxiliaries, no PC can ensure a perfect gaming process. However powerful it may be, the Internet connection must comply, otherwise, it may become a horrible process, unfortunately. I have faced such a problem recently too, and given it a lot of thoughts and searches. I was really amazed to find https://www.back2gaming.com/guides/10-ways-to-upgrade-your-setup-to-improve-your-gaming/, where I finally found the best router for gaming process support. Just a sincere recommendation for you in order not to let you waste your time seeking.
