- 21 Dec 2019
- Planet Thanet
Usually the extra 4 or 8 pin is for extreme overclockersHi guys quick question as I’m building this right now... the mobo cpu_pwr placement has an 8 (called cpu_pwr1) and a separate 4 pin header (called cpu_pwr2) do I need to use this second power header or ignore it? Build Hardware is as above.
thanks!
If not using liquid nitrogen or helium it's not normally needed
