First PC Build - Warning, thread will have blunders.
Hmm, could only seem to change one of them down to 3000. it wouldn't let me change the other column, so I cancelled without saving.
I'm doing and SFC scannow to see if it comes back with anything, but I don't think it will as it didn't when I scanned yesterday. This is really bugging me!!
Or i'll try and update the bios from the 'gigabyte centre'. Seems like I can update it by downloading it through there?
Edit: I'm scared to update bios.
I would not update the bios through the app centre seeing as the pc is not stable.
If you do decide to update the bios, put the file on a usb stick and use Q-Flash in bios.
Good luck and hope you get this sorted. :)
Ah okay, I decided to completely uninstall gigabyte centre anyway – it was getting on my nerves..
Seems to be running okay at 3000 at the moment, will have to see if there's any bumps!
