- 23 Nov 2004
how do i look at that mate?
fornowagain said:The TT 680w Spec says its got 52A for 12v. If you do the math it's more like 36A, should be more than enough.
You've done mem test and run prime '95 that would suggest your ram is ok (even with it being ballastix and likely to fair sooner or later).Ashcrapper said:Right, got prime95 and did clicked on torture test. Wasnt sure if you need to set anything up so i literally didnt do anything once installed other than click that. Theres loads of nonsense in the window but when i stopped the test this morning it says this:
Torture Test ran 8 hours, 14 minutes - 0 errors, 0 warnings.
Execution halted.
Does that mean my RAM/CPU is ok? Or have I not done it right
Ok, looking at the spec of the older version gives about 28A for the 12v. Still plenty.trojan698 said:It depends what version of the PSU he has. The ATX2.01 has different amp ratings compared to the ATX2.2.
Can you read off the ampage ratings for the 12v rails on the side of your PSU m8?
