Vive Link box won't work for Rift S, as it's HDMI and Rift S used display port.
Best thing to do is to buy 1m or 2m USB3 and Display Port extension cables and cable tie them together. You may need active ones though for the Rift S. I extended my CV1 cable by 2m and it worked fine, and made it much easier to untangle the cables after each session as you just unplug from the extensions rather than having to go back behind the PC.
