UPDATE
ok small update, I got some more fittings and tubing today
the purpose of this was to work out if I could move the pump down stairs and the 140 rad inside.
I got - 3x 45's
3x straights
3x 90's
2m of tube just in case (get it? in case
) (sorry lol)
Well, I started by turning the 360 rad round so the inlet and outlet were in the drive bays (DVD and blu ray drive had to be moved, no problem), I then started on the 140 which with two fans will not fit in the case. If I dropped to one fan and cut the fan mounts at the end of the 360 down it will fit but tbh it really doesn’t bother me having the rad external, it gives me some external drain points and frees up the inside which is on show.
I was however toying with the notion of getting a 120 and replacing the 140 but that isn’t important to me right this min.
To make the tubing go the right way i actually had to mount the cpu block upside down to get the inlet to face the outlet of the 360, i dont know if it was the way i first seated the block but i have lost 2c off my cpu?
The pump was a nightmare, it would not fit down below with the mounting bracket on so that had to go and it is very tight to the window so made a hum, I have the pump slightly angled and now it makes 100% less noise than when it was on the deck with the stand kit.
I have the pump on high now with less noise than when it was on the stand at low speed O.o
Any who now I have everything in place, when I get paid next week I will make a move on those vipers. If you notice I replaced the bottom 120 fan with a viper, I did this two fold 1) it was the only fan which wasn’t a viper and 2) so I could try and remove the blades.
Well I failed at that, I carefully pealed the stickers off which produced a small magnet on the back which is easily removed but from what I can see does nothing? I tried pulling it off (ready to destroy it) but it is really fixed on their very firmly so C'est la vie I will mask them up (all 11 of them!) and spray them red
