The lighting looks fine there, single light source and everything aligns
You can't spot any other of putting errors?
Patch 4 out now too. Any updates people?
Personally found that this game is great on the hardest difficulty, as you can die in a couple hits that feels a bit more realistic to me. Also it makes the combat more tactical and engaging.downloading the now,. any tips , tweaks?
- Updated PlayStation PC SDK to version 2.5 with support for processors that lack AVX2 instructions.
- Fixed an issue that could cause facial textures to be displayed incorrectly when running out of video memory.
- Fixed an issue that could cause shadows to appear smeared for a few frames.
- The gyro functionality of controllers can now also be used when Steam Input is enabled.
- Stability improvements to AMD FSR Frame Generation.
- Various stability improvements.
- Various user interface bug fixes.
No,not really, unless there is something in the Legends mode (which I never bothered with).So i have way too many game on the go or planned right now but GOT is one i always plan to buy but ive gone greedy in my old age and cannot play games that end when the credits roll, if i enjoy a game i want something to grind out so heres my question .
Is there any form of endgame content or repeatable content to grind?
I'm going to have to try this out, I was enjoying Sekiro for a while but I don't think I have the resilience to keep at it!
Is Tsushima a bit more manageable?
That's good to know. I think my 1070ti should still manage it at 1440p, will have to see if I can get in running at 4k on the tvDeffo yes.
I gave up on Sekiro a while ago (hope I can get back into it), but not sure I have the patience these days to master such games, but GoT I find easier to get I to, the combat isn't as demanding.
I got all the way to the final boss on Sekiro and gave up.
I had beaten every other boss and mini boss and had every health upgrade.No difference to a lot of souls like games in dealing with these kind of things.
The way I did it in sekiro (same for elden ring) was to farm skills points and go and find any items you may have missed that would make the fight easier.
In sekiro's case I just farmed skill points until I was strong enough to finish the last boss.
