Gigabyte AORUS FO32U2P Flat QD-OLED: 32" 4K 240Hz with DisplayPort 2.1, KVM
I know it is off topic a bit, but does anyone have and can share an opinion about the smaller brother, FO27Q3?
There are like 3 YT reviews and 3 written reviews only on this monitor and no respected sites seem to be working on a review of it besides rtings (but it seems at least 2 weeks away or more)
Quick tip for anyone mounting this monitor to a monitor arm, I had to use 8mm m4 screws to get a tight /snug fit between the arm bracket and the monitor. 10mm/12mm that seem to come with most arms will do the job but leave a little bit of wiggle between the monitor and bracket
This caught me out too, was surprised they didn't include any screws as i've used the same ones with my mount for the last 10+ years :D
Hey everyone, I was wondering if anyone who owns this screen has had the screen randomly go black during use, the monitor is not powering off and the game at the time is not being disrupted. I thought it was maybe having DP set to 2.1 but set it to 1.4 and it still happened. Im trying to figure out if its a problem with firmware or hardware as if its hardware Id need to rma with OcUK. Current solution to correct the black screen is to cycle the power button off then back on to get picture back.
Just bought and had the exact same issue. Monitor has turned off three times and once turned black and needed to be switched off and on manually. That's in maybe 15 hours of usage.
Did you get this fixed up in the end, anyone else have this issue?
I actually had to rma mine for a faulty vesa mount hole, but haven't had the replacement show any of the original screen issues. Very happy with it
I haven't had any issues with mine, have you tried updating the firmware?
V2 Firmware for the AORUS FO32U2P released 20/08/24
https://www.gigabyte.com/uk/Monitor/AORUS-FO32U2P/support#support-dl-firmware
Interesting, I've let OCUK know and I'll see if I should replace. Thanks for the info mate.
Just updated to the V2 Firmware, will keep my fingers crossed.
I can confirm this is an issue. There are multiple Reddit queries about this and I have the exact same problem. I've sent my monitor back to Gigabyte, they say they cannot replicate the issue and want to return it...which I've not accepted. I can easily replicate the issue and there are so many reports online about this. 4K 240Hz with DSC and display cable with HDR enabled and G-sync. Alt and tabbing rapidly on the desktop and switching between the browser (Firefox) and desktop force replicates the issue. It's usually random and occurs over a few hours when playing games and alternating between various windows or sometimes it just happens while in games. It's definitely a bigger issue than they think.
FYI I've just updated to the F04 firmware and it's pretty much solved my issues. Give it a whirl.
Think I've found the hdr sweet spot for this monitor, it now looks stunning with a balanced bright image that isn't too dim overall. HDR1000 enabled, contrast 58 to brighten overall image which gives max nits of 620 in windows calibration. Enable dark enhance and oof.
Lovely old job. Until now HDR1000 was too dim and HDR game with apl high tended to be a bit blown out.
So after 4 months it decided to brick itself in a continuous pixel cleaning cycle where the screen flashes between green red yellow blue white black. There is nothing that can be done to get out of it..
Now going through RMA process
You think Dell and Samsung have 0% failure rate?
I have only ever purchased dell or samsung monitors, this gigabyte monitor has been the first time i have purchased a monitor that is not dell or samsung and it faulted after 5 months of use.
P.S. i have RMA'd the gigabyte but at the same time i now own a samsung oled G80SD, when i get the gigabyte back it will go on ebay...
firmware F06 is out - updating as i write this.
I have purchased this monitor on 15.06.2024 for 1.3k. Use case scenario: work (from home) during the day, bit of show watching, gaming in the evenings, weekends. I do not own a TV.
Quick delivery from OcUK.
Further background info: I come from a 27" 4k 144hz IPS panel, work is spreadsheets / email / writing - no colour perfection needed. I can control the brightness in my room.
In no particular order:
  • Usage time: 950 hours, 124 Pixel Clean count. Eco mode disabled, other OLED saving settings left as default.
  • The contrast is phenomenal. For both SDR and HDR, game changer. To the point where I would not consider any future gadgets without an OLED panel - no going back.
  • Delighted about this purchase, to this day I am still amazed by the quality of the images displayed.
  • I daily drove a laptop with 16" 2400p 60hz OLED before this big 32" so I knew the big advantages in colours - even more impressive on this large screen. Laptop still in use.
  • Given the crazy high DPI of both my 27" and laptop, 4k on 32" at first doesn't seem enough. After one week working on it, I got used to it, more than good enough DPI. Still, looking forward to higher resolutions.
  • Whilst is very bright outside, curtains are partially closed - I did the same with the IPS panel. In other words, I wouldn't consider brightness an issue.
  • HDR 1000 in the evening is too bright - I either change to HDR 400 or I lower the brightness. Major bonus point for this monitor: brightness can be turned down in HDR!
  • The laptop had Dolby Vision support: never used it. And when I specifically looked for a DV source, I couldn't tell the difference vs HDR10. So no need for the Asus model with DV support.
  • It took me a while to get used to 32". I still prefer 27" when working on a single document, but overall I am happy to the 32". I won't go any bigger than this.
    • My standing table is 180x65 (lots of paper docs needed for what I do). Depth is not enough. Looking to change the table top to 80 maybe 90.
  • I have been burned in the past with Asus support (not the Ally, laptops deployed at my business). Gigabyte / AORUS has been great so far.
  • Hardware: speakers ok, useful if needed. I meant to buy a monitor arm, stock stand good enough.
  • Firmware upgrades will take a lot longer than expected - go make a cup of tea, leave it alone.
  • I am running the monitor with a fibre optic HDMI 2.1 cable - highly reccomended. Super thin cable, easy to adjust.
  • You can see the pixel shifting, no you won't care about it.
  • Looking forward for higher res + tandem OLED in 4/5 years.
A note about software: I use StartAllBack to move the Taskbar around, and Twinkle Tray to change the monitor brightness without the USB cable attached (DDC/CI).
Keep the firmware up to date and install the Driver from here: https://www.gigabyte.com/Monitor/AORUS-FO32U2P/support#support-dl-driver-monitor. Windows recognised the various HDR modes correctly after installing the driver.
FYI on my laptop, I left the taskbar as in, and used it for years. No burn in.
Honestly, now that the MSI 321UP is out, there's no reason to get this one. It's A LOT cheaper (£800 here on OcUK), only slightly lower refresh rate, 165hz vs 240hz. Unless you have a 4090, you won't be able to play modern games higher than 165hz. And if you have a 4090, a few hundred £££ won't make a difference.
Hopefully this helps with someone's buying decision for this Holiday season. Happy to answer questions.
In hdr 1000 mode set contrast to 58. This gives you a peak brightness of around 640 nits whilst lifting the entire image brightness up.
Screen blows my mind everytime I turn it on.
Won my first game of PUBG in ages (longest dry patch), has to be the monitor :D.
Edit - PUBG seems a bit stuttery yet one game was fine. Doom Eternal at 4K - so buttery smooth.
