- 9 Jun 2004
Sounds like the same problems I was having with a DS3 and G-Skill NR memory. I RMA'd the memory explaining the problem and they replaced the NR memory with NQ. The NQ memory is DR2 6400 but has a default voltage of 1.8v. I have had no problems since.Sawbill said:Well, after more fiddling, ran SP2004 for 3 hours (before I give up), but SuperPI would still not manage 4M digits without crashing.![]()
After this (about 6 Hrs running @ ~100%) I re-ran MemTest86+.
This time it threw out 1000s of errors! All only 1 or 2 bits in error, all in the last byte. All in 1 word sequences. All with addresses ending in C !
So I tried each memory module individually. Both worked individually (in both slots 1 & 3).
So I tried turning the DIMM Volts back down to normal (1.8v). One module still worked fine, the other would not POST.
Put both modules back in and vDIMM back to 2.1v and errors again - same pattern.
So does this sound like a Memory problem, Motherboard problem or CPU problem? Alas, I don't have any bits to swap out. My nearest alternate PC is much slower (so would not really stress things much).
I had hoped to have this working by Xmas, but that is not looking promising if I'm going to have to start RMAing bits at random!
In a nutshell, it sounds like a memory/mobo compatibility problem to me.
