Got myself a GA-P31-DS3L yesterday and already have a Q6600 running at 3.2ghz with 1.35 vcore which I am well chuffed with, however I have been having some memory trouble with the board. After many determined attempts to run two sets of OCZ platinum rev. 2 PC6400 memory the machine just will not boot with all of it installed, my only option was to remove half of it and then it would run perfectly.
Apparantly this problem is due to a "chipset limitation" in the P31, it will only run 4x "single sided" modules and not the double sided type which most memory is today. I ended up replacing both sets of memory with one set of OCZ 4gb Vista Gold Series memory but once I got around to installing it I found out one of the new sticks were faulty! One stick would not get past POST without freezing while the other is prime stable.
Anyhoo I will be replacing those tomorrow with another identical set and hope it all works perfectly afterwards. I just want to know if anyone on here has experience with running a P31 chipset with 4gb of memory?
I have the same board and run 4 gig 2x2 of ocz,the first lot i bought one stick was faulty and had to have the ram replaced
when the new ram arrived i had the same problem as you would only boot up with one stick,when i tried both it refused to budge,i took 1 stick out and increased the ram voltage to 0.3 which i think runs the ram at 2.1(i may be wrong though)
Anyhow i put the other 2 gig in and it worked and i`ve been it using it for a few weeks now with no problems at all
Hope this helps
