Having a lot of trouble with a P35 DQ6 here.
Was previously running okay with a E8500 and Crucial Ballistix Ram (2x1Gb).
Flashed the BIOS (using Q-Flash) to get the half multiplier option and now the machine won't start POST and power cycles.
I bought some Geil ULL 6400 RAM a I thought that this was the most likely cause - but I get exactly the same issue. Also tried clearing the CMOS for 30 mins.
Anyone got any ideas before I send this cr*p back?
Hi all,
Is anyone running a Tuniq Tower 120 on the Gigabyte GA P35-DQ6? Is there any issues of that heatsink not fitting?
I have seen it cheap and may purchase it if the Tuniq Tower fits.
Thanks
Hi all,
Thanks
Upgrading from Geil ULL PC6400 to G.Skill PQ PC2 8000, the G.Skill runs at 500 right? Can P65 DS3s manage that? What is the best course of action in terms with multiplier, fsb etc. My 6300 can manage 3Ghz+ fine
Clocking
1. Make sure that you have the latest chipset drivers and flash the board to the most recent bios version
2. On the main bios screen press Ctrl+F1 to open the advanced options within the menus
3. In the Advanced Bios Features Menu, Disable all of the following: CPU Enhanced Halt (C1E), CPU Thermal Monitor 2(TM2), CPU EIST Function
4. In the PC Health Status menu, set the FAN Speed Control Method to "Legacy" & FAN Speed Control Mode to "PWM" to maintain highest speed
5. Go into the MB Intelligent Tweaker (MIT) menu at the bottom of the page, set the System voltage control to "Manual"
6. These boards have a default VDIMM of 1.8v, set the VDIMM to co-ordinate with your ram. The Geil I have is specced as 2.1v so I have mine set to +0.3v
7. Set the MCH Voltage to +0.1v
8. Set the FSB Voltage to +0.1v
9. Set the VCORE to 1.45v - Please be aware that this will increase temps!
10. Set the CPU Host Clock Control to "Enable"
11. Set the System Memory Multiplier to "2x"
12. You're set to go, just increase the System bus Frequency to Overclock
13. I would reccommend that you use Intels TAT to monitor temps
The board certainly can handle memory at 500mhz.
Do you have a x2.4 memory multiplier on that board? I can't remember if it was ever given one. If not, then it's debatable if the memory will run on the x2.5 multi at 3ghz (429x7).
