Now taking the side off is an issue .
I can't do much with it until my CPU and motherboard arrive anyway, It is currently a desktop ornament
Custom loops can be very nice, but they are definitely very expensive and do require at least annual servicing or corrosion will set in and distroy them. A well setup air cooled system is as quiet unless pushing extreme overclocks running at high load, and even then a well setup air cooled system will only be a couple degrees warmer. My i7 920 @ 4.2GHz air cooled system has been runningAt the minute, I'm only going to be running a Ryzen 3600 and probably won't bother with an all core overclock.
In the future, I plan to drop in a 12 core or possibly even a 16 core chip when prices settle and then just leave it for a number of years.
I built my 2500k setup back in 2012 and never touched it since so my builds last me a good few years.
If I do go down the 12/16 core chip route, I may have to look at a custom loop. I don't think I would ever go for an AIO now.
Yes and no. Some of the top performers air coolers are chunky and few of them my sit too close to the GPU/first ram slot or even don't allow tall ram. Not a rule, but may happen.I'm just getting some bits together for a new Ryzen build and was wondering if a good AIO CPU cooler would be beneficial over a good air cooler.
I think the last time I looked into this, the general consensus was a good air cooler out performed an AIO. Has this changed?
This.I've got a i4770k that's been running at 4.6 Ghz for the last six years on a Noctua U14S. Apart from blowing the dust out of it once a year, it's zero maintenance. I don't even think I've changed the paste on it. It's mostly silent except under load, and then it's just a whooshing sound that you can't hear six feet away.
If you want to use your PC, go aircooling. If you like to fiddle about with it regularly, and are happy to risk water in with your electronics, then go water.
This.
I use my pc a lot, but allow myself few days without it if needed.
Since I was a kid, always enjoyed dismantling my toys, and usually spent more time assembling them than actually playing with them.
Still behaving like that, at some extent. Always an unjustified pc upgrade, just for the sake of change or an ongoing project at the house or the car.
If it helps, Linus Tech Tips recently did a test and the results were surprising:
For me there's another issue with AIO's - the inability to refill them. Over time I'm guessing like any water cooling system, the fluid will degrade and pick up organic deposits and the liquid could reduce in volume. The inability to refill means it's new cooler time.
I really wanted to go with an AIO, but they seem very difficult to justify - worse cooling, less reliable and throw away every couple of years?
It's worth pointing out here that a specialist water cooling system is another matter entirely and will out perform an air cooler.
Yes, If I could justify the cost of a custom water cooling setup I would but at the minute, I've just gone for a 3600 CPU and will play about with the RAM and infinity fabric.
I know there isn't much to be had from overclocking the Ryzen 3000 series so felt a good air would be better suited for the job for me cost and maintenance wise.
That's not quite true, in particular the reliability/throw away at 2 years. Yes an Air cooler over a duration of say 5 years or more is less likely to experience mttf than an Aio cooler my old titan Fenrir must be close to 10 years old and is still strong.
You can target Coolermaster seidon v1/2 as an example of an Aio with a high failure rate, maybe a few others.
However BEQUIET's Aio range have a refill port either in the pump or the rad and also feature g1/4 threads for system expansion. There are a few other manufacturers with refill port/expansion options ALPHACOOL, EK .
With regards to the fluid evaporation loss on a sealed system (no refill ports), then there's a very low chance of that occurring but if it did and you noticed the gradual symptoms, pump noise, air bubble noise, lower cooling performance then you can go the warranty route,
or if you are out of warranty then there's nothing stopping you from checking the aio loop out, or manually taking apart the aio system to refill the system.
At the same time if the pump totally failed but the rad was still good you could just buy a reservoir combined pump and reuse the coolant tubing or make up your own/ add a takeoff for a gpu block/cpu block , (7/8mm tubing etc).
So whilst I agree that there are situations where an air cooler is a better alternative, in retrospect there are situations where an aio is the more suitable solution.
I disagree with your viewpoint ''worse cooling, less reliable and throw away every couple of years?''
So if All that were to go wrong in a couple of years when your warranty is out, How much will it cost in upkeep? Fluids, Expansion, Pump, reservoir etc? Be as well go custom loop?
A little difficult to clarify as lots of variables , but most warranties are 2 or 3 years and then if you buy the aio with a refill port, then you are looking at the cost of the coolant of say £5-£8 or just distilled water to top up £1-£3.
Say the warranty was out, then If you had a cheap thin walled 120mm rad aio and the pump failed it probably wouldn't be worth upgrading or saving. But If you had a 120 thick wall/240/360 rad then you are 1/3 the way there to going custom, a good cheap reservoir pump would be £30-40.
You might need new tubing £5-£20, or reuse the tubing, you could gut the internals out of the aio dead pump and resue the block or just put on a new cpu block (price).
edit, but as some have already said, Ryzen 3*** doesn't have any overclock headroom, so really the best solution in my opinion would be a half decent air cooler.
