I think it will be quite a bit more more powerful than the 480. How damaging it is to AMD depends on the price.
The rumours are that it's 2x as fast as 480:
*Graph*
15% faster at 120 watt, my next GPU right there, when Nvidia milk us for it.
FTFY....
Its also going to be more expensive than the 480, and probably more expensive than the custom 480's, yeah good luck with that![]()
1070 with an OC.
at 1700mhz with 1280 shaders it has 4.4Tflops
if it makes it to 2ghz with 1280 shaders it will have a theoretical of 5.1 Tflops, but it also has a smaller memory bus. So not even near a base clock 1070.
Isn't a RX480 at 1266 something like 5.8 Tflops theoretical? I'd be seriously impressed if 1060 managed to beat RX480 by 15% while having 12% less theoretical Tflops. Then again I wasn't really following the cards before and how Tflops scale with performance.
TBH seeing all the issues Greg is having has put me off the 480.
That chart is total BS. Look at the scale on the x axis - starts at 0.8 in order to mislead readers. It doesn't show the 1060 is 2x faster, it shows it's about 15% faster.
And considering the obvious bias of the source, I'd take even that 15% figure with apinchtruckload of salt.
