This page has benchmarks at difference latencies:roadie said:I can't remember where I saw the benchmarks but I am sure someone else can.
Thank you!clv101 said:This page has benchmarks at difference latencies:
http://www.tbreak.com/reviews/article.php?cat=cpu&id=456&pagenumber=2
Fast timings seem to make very little difference.
Shakey_Jake33 said:Here comes the ultimate newbie question guys!
Which RAM should I be looking at for a stock, non-OC'ed Conroe Extreme Edition X6800? A dumb question, but I'm really not too knowledgable on DDR2, being an AMD user for the last few years.
Minstadave said:Gskill PC5300 for under 120 quid inc VAT or the Corsair PC5400 for 135. Both are excellent 2x1Gb kits and offer great value![]()
AMDPower said:@Drazic
did you manage to overclock the Es6700 to 3.7ghz on air?
is that the max u managed?
thanks.
Stupid Q, but I assume the fact that the Corsair stuff is noted as being 10MHz higher really doesn't matter, right?Minstadave said:Gskill PC5300 for under 120 quid inc VAT or the Corsair PC5400 for 135. Both are excellent 2x1Gb kits and offer great value![]()
Drazic said:It's alright, you'll be overclocking that ram by a milestone however
PC 8000/8500 is what ya want as it's 1000/1066 mhz respectly which is nearly and what is Conroe
Oh and 1:1 does mae a massive differnce on the system. I just set some news speeds with it hehehehe
No, you don't. The chart only goes up in 10Mhz. With PC5300 being 333Mhz stock that's all you need. Although obviously you can buy faster RAM and run it at that speed.Sem said:sorry if this sounds dumb but im not an expert of DDR2
i plan to buy a E6600 and overclock it to 3.3Ghz (333x9) or hopefully 3.6Ghz(400x9)
according the to chart i need DDR2 6400
what would be the better choice
Corsair 2GB DDR2 XMS2-6400C4
or
G.Skill 2GB DDR2 ZX PC2-6400
the timings for these are 4-4-4-12
will i need to reduce them in anyway if i want to run 333/400 FSB
thanks
Explicit said:G.Skill 2GB DDR2 HZ PC2-6400 (2x1GB) CAS4 Dual Channel Kit (F2-6400PHU2-2GBHZ) (MY-013-GS)
£173.84 inc VAT
http://www.overclockers.co.uk/acatalog/GSkill_Memory.html
Best RAM for overclocking Conroe now listed on site!![]()
Beenom said:Is there a major difference between the HZ and the ZX series? The HZ has 4-4-4-5-15 whereas the ZX has 4-4-4-4-12. And there's only £6 difference...![]()
