Dr Jones said:The HZ, as pointed out by many, is able to overclock above 1000mhz. That's like a Memory worth £300 at the price of £172ish. Bargain!
DDR2 timings are the same as DDR timings in what they do. Slack timings make hardly any difference because of optimisations in the core 2 processor, go for bandwidth. I've got myself some nice PC2-8000clv101 said:Can someone point me towards a DDR2 timing parameters tutorial?
monkeypants said:I've got myself some nice PC2-8000![]()
Bwahahahahaha... T'was an RMA from OCZUKTopGun said:Whats the point buying PC2-8000 when for the price you could have saved buying the PC2-6400 HZ kit you could have bought an E6700?
Kesnel said:Sorry, forgot to mention also that the HZ must be dated May 06 or later. Look out for the 0605 sets as these use the Micron chips, earlier versions use the inferior clocking Elpida ICs.
Kesnel said:Any later than 0605 inclusive have the Micron IC, so you're ok with 0606, same month as mine.![]()
Basically, yes. It does make some difference but it is more 5% on average only. Still, I didn't buy the RAM for timings really, more for clocking potential and price.-|ScottFree|- said:Im sure I have read that the memory timings are not as crucial to Intel chips as they were on the AMD's.
Im a right in suggesting that Intel's prefetcher masks the latencies of memory and so reduces the importance of tight timings. So if you are using a Conroe, altering the timings will not give you the gains it did when altering the timings on our AMD based PC's.
