That's my understanding, DDR2 5300 is fine, even for some pretty impressive overclocks.Flanno said:Surely if you buy a mid range Conroe, then DDR2 6400 800mhz is a complete waste since Conroe will never be able to reach the max. bandwidth of this memory which is 12.8gb/s, even when the cpu is oveclocked.
i wouldnt have thought so as it was out of stock then back in stock before i ordered it about 1 mnth ago ill have to check, i can only get ddr1000 with the cpu running at stock, if i use a higher fsb 420 for example max i can get the ram to is about ddr950 or something
