im trying to do it now! Its a lot easier than girder, just drag and drop commands over to another panel.
let me know how you get on
just had a quick fillde and got MPC to open file via mce remote![]()
hopefully i can grab dingleberry's xml file for eventghost. Then it should be plain sailing!
well im reading through that thread and its hurting my head!
Why cant things just WORK!
im gonna google for a MPC xml file for event ghost. That should be check mate for us if we can get one!
Ye should be plain sailing form there. "MPC xml", "media player classic xml file" in google didnt show anything useful though....![]()
Whats wrong with mediaplayer 11? I can get that working with mce remote & MP.
aaaaaaaaahhhhhhhhhhhhh eventghost wipes out mediaportal & mce support. I think you will have to install the mediaportal plugin inside eventghost lol...... i dont think its worth it
im just gonna adjust levels in ffdshow if i think its to bright
All this remote business has made my head hurt, enough is enough. I'm calling it a day.
You got WMPC or KMPlayer working with it?
just tried event ghost, its as easy as a cheap hooker!
Dingleberry can you send me your xml file file please, would be easier for me, my brain hurts so much today?
Would you mind e-mailing it to deanbeamish at googlemail com ????
I would love you long time if you did.
aaaaaaaaahhhhhhhhhhhhh eventghost wipes out mediaportal & mce support. I think you will have to install the mediaportal plugin inside eventghost lol...... i dont think its worth it![]()
Very interesting read - got a few questions if you don't mind...
There's no mention of TV - are you using a separate solution for this such as Sky+ and the HTPC is purely for other media files? I'm using VMC myself for TV as I like it but am looking at using MediaPortal for other files.
You say you're using Mediaplayer Classic - do you mean you have MediaPortal set to use this for playback rather than the built-in player? If so, how well does this work? Have you managed to get the MS Remote to control MPC well?
Doesn't surprise me tbh - I had no end of trouble last time I tried to use it.To be honest with you im thinking of dropping MP all together and going back to the old fashioned way of just launching files in explorer
I do the same although I've yet to find a slick way of adjusting the refresh rate between 50Hz and 24Hz when playing 24fps material. Media Center really doesn't like you trying to mess with the refresh rateMy solution to this has been to use Vista MCE with a codec pack to literally play back everything including embedded AC3 and DTS. You'll have to configure AC3filter for that though.
Yep, changing the refresh rate of the graphics card to 24Hz - obviously only if your TV can support it.
