- 11 Jun 2013
Try the Home Gym thread, but I would definately recommend the Bodymax CF415 - cheap and works really well for what you describe.
Very slowly, and with as little weight as possible.![]()
There is a thread linked in the OP of the GymRats 2014 thread, which outlines some very basic bits for Olympic lifting, too.
How good is your mobility (ankles, hips, back, shoulders)?
Only one way to find out...
Aha that's the guide I've seen before! Knew I wasn't imagining it, lets see how good this guy is as teaching the lift![]()
- not sinking too low (try for parallel);
- keeping your knees tracking outside your big toe and bracing them hard (the "knees out" cue can help this, but I find "heels out" works better for me, personally);
- keeping your chest up as you squat: this actually means keep your back tight.
Quick question.
Mostly focussing on building muscle mass at the moment (and doing pretty well), but I do enjoy the odd medium distance run! Fancying a 10 mile run today, but is that going to seriously counteract my gains?
Its hurting your lower back because your lower back is bent to buggery. Try working on some thoracic mobilisation perhaps? I also personally don't like having my heels up, try them flat.
Remember, what works for a short stokcky diesel strength powerlifter doesn't necessarily work for everyone.
The weight you are pushing appears to be quite high relative to your 1RM as so it looks like you're struggling so not the best indicator of form.
As Delvis identified you appear to be arching your lower back way to much, and have not got a solid base with your feet to push from - can you lower the bench or put plates under your feet?
It doesn't look like your chest is set before you begin lifting - your abdomen looks higher than your chest. There's also a curve motion to the centre section of the bar - its not going perpendicular up and down?
