Man of Honour
- 16 May 2005
- Manchester
Probably bad form or too much weight too soon. Can you post a video?
Must be crap form I guess.
Quick deadlift question as i've started going to the gym with a few mates from work and they're picking holes in what i'm doing and not willing to listen to what i think.
At the top of the lift is there any need to hyper extend and lean back? They're both completing the lift then doing this 15 degree or so lean back and pulling there shoulders at the same time.
I was under the impression that once you're up and your back is straight, the lift is complete, any further movement is redundant. Also from what i've read, the shoulders should already be pulled back and held in position while you perform the lift. I believe that if your shoulders are pulling forward, the weight is too heavy.
If of course i'm wrong, please let me know so I can correct my lifts.
They're also telling me to use straps instead of mixed grip as i'll never be able to lift heavier weights if I don't.
Someone can word this better than me.
With deadlifts, most people have rubbish technique and don't know what they're doing. They don't hip hinge properly and lift with a banana back so when the bar gets past their knees, they have to straighten out their spine to get the bar to their hips (usually knees are still bent so they have to 'hitch' the bar up) then hyperextend at the top because they think they're getting a full ROM this way.
If you deadlift properly with a correct hip hinge and neutral spine throughout, the hips come to the bar and everything below (knees, ankles) ends up lined up nicely to finish the lift - dat gluteal squeeze is the coup de grace rather than turning your spine inside out.
Hyper extend no, finish the lift yes.
Straps, nothing necessarily wrong, mixed is absolutely fine, although some would say do double over hand until you need to use mixed....then others always use mixed regardless.
Just let them hyperextend and be done with it![]()
You do not need to extend
Regarding straps vs. Mixed grip? Be a proper joss and go for hook grip.![]()
Thanks both. My piriformis has been a long time pain in the arse (literally), gets a near daily rolling now which seems to have helped somewhat. I'll focus on knees out and not forgetting form on the last couple of reps. A video will follow for everyone to have a laugh at though.![]()
The one thing that stands out to me is "pushing knees and heels out consciously". Knees I absolutely agree with but I'm not so sure about heels. Could you explain this one a bit more?
I drive through my heels (in fact for a while I'd wiggle my toes a little before the squat just to 'remind' myself) but I don't drive my heels outwards - wouldn't that encourage you to drive your knees inwards a bit?
Maybe I'm just misunderstanding the description![]()
I think I get what you mean and it makes sense. I guess I wasn't really thinking of driving heels out in that kind of way![]()
Yeah, I bet I squat way more than you.
..in my dreams![]()
