Post up some vids and try and get at least back and side angle for a better look at what's going on![]()
I have side in vids already but would benefit from seeing good form in the flesh. Maybe once I have a better base...
Then ask questions! If you read the last few pages you'll find other deadlift critique.Ice - Yes I've just watched them all again having watched them in the summer. I've taken some notes and realised I'm doing some things wrong but I still sometimes struggle to understand what they mean. Opening this, tensing that etc.
Actually no.I think the main problem for me seems to be the initial drive off the floor, I just cannot stop my hips from moving upwards before my shoulders. From what I gather the bar is supposed to travel to your knees and at that point you then bolt your hips forward and tense the hell out of your glutes but the initial movement I seem to struggle to generate power or understand where it's supposed to come from.
2) Have tension through your glutes from the start (spread the floor with your feet and externally rotate the upper leg)
but who was glutes.
I'd work on your hip hinge, build up your movement pattern using RDL then you should have a better base for doing deadlifts. Right now, you're basically pulling that weight off the ground with your back.
When you say externally rotate the upper leg is this supposed to happen at the top of the move?
See this is my problem. Call me a muppet or whatever but I don't understand that sentence.
My foot is flat on the floor and remains so throughout the move and I don't know what externally rotating the upper leg means. All I can think of is it twisting which isn't right!
...this is why we watch the videos!
From the OP. It shows what was quoted![]()
