The pilots came in too slow to land, weren’t monitoring instruments and didn’t pick up that the aircraft was losing altitude too quick till it was way too late.
Both pilots survived.How can the black box tell you the pilots were not looking at the instrumentations ?
Also if they have recovered the bodies from the crash of have thought the helo itself would be brought up for investigation?
If helicopters move to slow they create they're own vortex with the rotors causing them to suffer reduced lift, because the pilots didn't realise this the helicopter basically stalled and plummetted to the sea.I read that part but I'm still unsure as to what not monitoring instruments and coming in too slow would do to the aircraft?
According to one of the survivors the the helicopter catastrophically failed mid air:
"And then Sharp heard "a whoosh, and a crack like someone cracking a bone. And the chopper turned on its side, in the air." Nugent heard the bang, too: "An almighty bang, metal on metal, above our heads. It was loud. And I was just, 'What the…?' And then there was this twisting of the fuselage, left to right, very rapid, very violent, very sudden, and I thought, oh no, there's something wrong. I looked at the others and there was shock and horror on their faces. I thought, no, we can't be crashing. You don't want to believe it."
That was taken from this guardian article:
https://www.theguardian.com/world/2...ter-crash-survivors-britains-toughest-commute
Edit: Possibly conflating it with the other crash with the gearbox failure?
Ah, possibly looking back.
Always wondered why they don't install an inflatable device on the top of the helicopter as well to help prevent it being upturned?so it would kind of rest sideways at worst.
The blades hitting the water at the point of impact help flip it over, no amount of flotation up top is going to help you.
Ditching at sea was my worst fear when going offshore, the training will help you get out of the helicopter but if your leg or arm is bust / trapped or you get knocked unconscious then its time to say goodnight.
That still happens regularly.Or if like me you got stuck next to the fattest lump of a man ever and the crew ignored procedure by having him next to the window that he couldn't physically fit out of...
I work in the north sea and I didn't realise it was pilot error, I always thought it was a fault with the chopper maintenance. Is this a case of them finding someone to pass the blame onto or can someone else who has more knowledge on flying a helicopter explain what the pilots did wrong?
I agree, it's really sad to hear that 28yo lad killed himself on the back of this.
Sums it up pretty well.I did Dunker training a few times and it always struck me in the same way as the "Nuclear bomb" drills we did - unless absolutely everything goes perfectly then you will be lucky to survive. All it takes is one single break in the chain and your chance of making it out that helicopter are reduced to almost zero, so the training, whilst effective for a "perfect" crash, always felt more like "well, we've trained you so you should now feel more confident about surviving a crash, but you probably won't, good luck!"![]()
I remember the first time we tried to do an inverted escape on HUET and the person sat to my right side completely lost their bearings and ended up smacking me in the face and ripping the breather out of my mouthstill one of the more "fun" training courses for the industry though!
