HELP!! ATI Tool broke my X1800XT
Thanks for that. I will have another try later. Should I up the MVDDC and MVDDQ voltages as well?
I just checked the temperature again and it seems to have settled at 78-79 degrees.
Stan :)
Stan :)
The memory is a wierd one.
Some cards actually benefit from you undervolting the memory and get you higher clocks, whilst for some reason others find higher voltages better. Also with the MVDDQ voltage, never raise that above the voltage of the MVDDC :)
OK. Will have a bit of a tweak later and let you know how I get on.
Thanks for the advice :)
Stan :)
