- 14 Sep 2011
Didn't wait a minute though......I did that... nothing!!Didn't wait a minute though......
I first tried it when the PC was on for some reason - can that break it?
No idea.
Unplug the power cable.
Leave it for a minute.
Press the power button on the PC to drain any residual power then press the clr CMOS button.
we're back!!
just having to reset default ....settings :/
Very good.
Now be more careful this time![]()
ahh what the heck I just used DEFAULT settings at 3.3ghz and ran the intel burn test and the PC froze AFTER it successfully completed ???
argh that's worrying?????
I can see the windows screen but the mouse isn't responding
yer it hasn't worked .... what to do next then ?? can't even get a display any more
Try connecting to the video outputs from the motherboard and see if you get a display then.
You may have to remove your graphics card (I'm assuming you're using one).
Are you able to get into the BIOS?
Just keep bashing the Del key as soon as you switch on.
I think the flashing "_" is because it can't find a boot drive.
If you can get into the BIOS set your HDD as the first boot device.
do you mean swap the optical drive and the HDD?
