Help Team OcUK beat some Russians…
Make sure the power saving features are turned off when its on AC power...its still clocking down the CPU as though it was on battery power. You'll find the options in Control Panel->Power Management or something labelled similarly. That might explain the high ETA.
Generally it will speed up when CPU percentage use reaches a certain point. At 100% CPU speedstep should not function.
Are you using some sort of battery saving tool or somehting along those lines?
EDIT: Too slow again.
sr4470 said:
Celeron-M > Celeron-D, even though the Celeron M is usually running at half the clockspeed of the D. Pentium M will be light years faster.
I know.
I was just showing that there is a worse computer then a laptop running folding :)
Ok i just checked the power settings and It had maximum battery on for some reason! :confused: Never seen it like that with the AC power. Anyway I changed the setting from that to minimal power management. Unfortunately there's no way to turn it off as far as i can see... There's also a maxiumum performance option.
It's still around 900Mhz... Should I restart?
Zip said:
I know.
That Pentium M isnt far off an Athlon 64, clock-for-clock in folding. It'd be faster than an Athlon XP and some Pentium 4s (depending on the exact work unit).
I know that to :)
I first started in these forums up in the hardware section untill i found GD :p
Celeron D sucks dogs danglys :(
It pobably wouldn't hurt.
The Pentium M is an excellent CPU for FAH. A 2.0 GHz Pentium M at stock everything holds the world record for PPD. The owner of that machine is my next door neighbor. :)
Zip said:
I know that to :)
Oh, sorry. Take it you do dont much on the pc then...
Use the maximum performance option.
I just go on the Internet and on here most the time and play certain games in low settings :o
I know i have a crap spec PC buts its all i could afford :(
Ah right...you'd be suprised what I made on a low budget with used parts ;)
this cost me only $1200AUD
Mum wouldnt let me build one :( :mad:
And our parts are more expensive down here then over there i find.
It bet all the competitions prices anyway and we just really needed a computer.
The 6 months or so with out one was hell :(
Hmmm n00b question but can you run this folding lark on a server?? ie will it run on win server 2k3??. If so i might as well help out as my server is on 24/7...nothing too great though...but as i said every little helps...
Run the 2000/XP client. That client will also work on WIn 9x machines just so long as you don't tell it to install as a service or ask for big work units.
5.02/5.04 runs just fine on Vista as well.
hi well after reading this thread thought i would try help you out abit downloaded it all did the advanced settings etc only on a p4 but all helps i surpose Current Work Unit
Download time: June 13 13:20:32
Due time: July 10 13:20:32
Progress: 15% [|_________]
BillytheImpaler said:
w00t! Thanks for joining up, ToLearn. I'll see you in the news this Friday. :)
*ahem* Thursday *ahem* :p
i'll be keeping the news on Thursday through the summer so it doesn't get interrupted by me going away/being out for the night :)
Great to see lots of people joining still. :)
Lots of you don't seem to be aware of fahmon. It will tell you what units your cruching, how many points there worth etc and its easier than looking in the text file. A handy little program if your interested in the points side of things.
