How on earth can you accurately measure when you have used £5 worth?
When you refill after using a "tank of fuel", how many litres go in? I would be very surprised if you are actually averaging anywhere near 23mpg!
I would validate your economy exactly before investigating possible problems.
my light comes on, i put £5 in, when i have used £5 the light comes on???
it may not be accurate to the ml but its close enough.
mine cruises comfortably in 5th at 30 so long as the road is flat, my dads old 02 fiesta did not and needed to be at about 35 in 5th.
That's still way too small amount to get an accurate reading.
Calculate it over 2x full tanks at least
Issue I have is that with my 1.25 2006 Ford Fiesta, I'm only getting around 220 - 230 miles from a full tank.
I do 60 miles a day for uni and it's done on A-Roads so there's no stop-start and it's at constant speed of 70mph.
It's been serviced every year and just had it's last service two months ago and it's MOT a couple of weeks ago which it passed with no advisories.
I'm stumped to what the problem is. I also feel the cars not running as smoothly as it should be. The tyre pressure etc is all correct.
Those gear changes look like those of a person determined to get into top gear as soon as possible, and then stay there.
