There is four files in the x64 Vista version. It's been linked to on the first page in this post.
oh yeah, I see four files, so do i install the bat or exe first?
These are files you should end up with, after extracting the download, run Atsiv, then coretemp-startup.
You will need to run this every time you want to run coretemp.
Are you extracting the download to a new file!
Rob![]()
Load the coretemp-startup .bat file before loading the CoreTemp .exe.
see my current idle temps below....
That VID is crazy if it's correct
Get some load through it.
Well VID usually ranges from 1.25-1.325v, with lower being considered to be better.
I'm making the assumption that Speedstep doesn't interfere with the reading of the VID. If it does then it might actually be higher than is being shown atm.
Are you sure the TT isn't jammed against the chipset heatsink or anything?
The TT definitely needs to be reseated.
