well it sits right over the northbridge heatsink, which gets quite hot, but it isnt touching it.
what will reseating do, becasue that means taking my pc apart again![]()
To be fair i to had to re seat my CPU again, cos i was concerned about a 7c difference between cores. I actually lapped the cpu and HS, put it all back together, and although each core was about 2c cooler the difference in core temps (7-8c) remained. So in my case it wasnt worth it much apart from experience, but your stock temps do seem to be abit high. Maybe you should lap your cpu and HS??
I used the clingfilm way like you said you did, how much TP did you put on the cpu, i put a size, smaller than a pea but bigger than a grain of rice if that helps
I would, that Tuniq is a pain to do in the case. If your confident you can do it, then go for it.
Might be worth taking it out.
I'd prefer to spend 20 mins taking everything out my case over 40 mins of swearing and wishing I had smaller hands. lol
But that's just me.![]()
All about the way u lay it and mount it![]()
Ive used them 3 times.
first time, it was delivered late, and to the wrong adress
second time they just didnt bother to deliver at all and made me go and collecxt it from there depot which is nearby as it goes.
and third time they got it right, except they crushed my Tuniq Tower box, so all the thins were bent.
http://forums.overclockers.co.uk/showthread.php?p=10647465#post10647465
How badly damaged were the fins on the Tuniq?
