Why are you guys topping out at 70ish degrees when with only 1.15v running through two of them in crossfire, I'm reaching 94-95c?
It's not like my airflow is particularly bad, it isn't great but I have a decent push-pull config running. :s.
What version are your cards? are they right next to each other? CF cards are always about 10C hotter than running a single card.
Yeah I think ASUS is just picking the voltage up wrong, as you wouldn't be at 58C at 1.21V.
That's the kinda temps i'm getting at stock.
As I say, try setting voltage to 1.15V and core at 1150 and give it a go.
Need 4xAA and normal tess on
Just use ASUS Tweaks monitor to post your temps and whatnot.
You still haven't got AA x 4 applied yet going by that screenie. In settings box, the box called "mode" should say 1920 x 1080 "AA x 4", not fullscreen. I think you might have applied AA in the CCC, but it needs to be selected in the Tweak tool. Make sure your CCC settings are showing, under AA options, "use application settings" this will allow to tweak tool to apply the correct amount of AA
Rumours are rubbish. Everyone here is using cards with a single power connector.
My MSI does:
1200/5800 @ 1.15V
1225/5800 @ 1.17V
1290/5800 @ 1.225V
YupBut each card is different.
As I say try 1150mV and 1150Mhz core and see what happens, and work from there.
