You are correct. Heaven is just an indicator of stability. You will need to test in other games to ensure complete stability. Crysis 2 is a good test as it's very hard on the card.
In other news, had a go at getting a heaven bench at 1290/6200 but it wasn't having it. Doesn't like running the high memory AND high GPU at the same time unfortunately.
So I've settled for 1225/6000 @ 1.17V as my day to day OC.
I noticed my FPS is far off from your previous results. I only yield 53.1 FPS at 1225/6000 @1.185v, does this means my i5-3450 is bottlenecked?
