145C![]()
im presuming thats 45C, would I be right in thinking the gelid fans dont plug directly into the card? What about the AC TT 2?
Errr....yep thats a typo, 45c is what I got under load.
Secondly the fans on the Gelid cooler don't plug into the card, just straight into either a mobo header or 4 pin molex, but one of those simple inline resistor cables to drop the voltage to the fans does an amazing job of lowering the fan speed, making them inaudible and they still keep the card at 45c. You also get a bucket load of heatsinks for the Vram chips and voltage regulators and the adhesive thermal pads to apply them which worked very well when I used them.
I can't speak for the AC TT2 as I didn't use one but I can thoroughly recommend the gelid.
