The corner bleeding has dissapeared again now... odd.
Try setting your ps3 to output 1080p only go into the display settings in the ps3 and uncheck 720p/1080i this will force the games to run in 1080p i heard it might make a difference but i havent tryed it myself yet.
I dont now how to update the firmware i dont think there are any other versions out yet.
Well guys, i got my other W241D Monitor back from Hyundai but it still makes the Buzzing noise,
They have asked me to send a recording of the noise , which im about to
Can someone download this and see if they hear it too
May have to turn speakers up
Thanks
http://www.megaupload.com/?d=2SRPUZBH didnt know where to upload it to so sorry if its rubbish
yea i hear it
btw call of duty four runs in 720p, 1080i and 1080p, well thats what it says on the box.
when i play cod4 on my ps3 through hdmi on my w2d40d it looks fine. I ticked all the display formats in display settings too. :/
you changed sum setting on the screen?
btw does anyone know how to reset the defaults on this monitors settings???
guys, a quick question.
How would you connect your Wii/PS3 to the monitor and also acheive a sound output? I know it has 2x3W speakers built in....but what if i want to use my PC speakers for instance?
Anyone know what cable splitters etc i would need?
what do you mean by ticked? i didint know you can select all of them at once i thought it changes one to the other as you select (i dont have a checkbox on my OSD); at least that is what happens on mine.
You can go back to defaults by selecting the Recall option.
On the ps3 video output options i do hdmi as vido output>custum settings> then there is a list like this and it says supported resolutions (or summin like that):
576p
720P
1080i
1080P
With little tick boxes next to them, and i ticked them all, that what i was trying to say if u didn't understand :/
and thanks for telling me how to reset the defaults
