I got me a laser cutter, awesome!
That's awesome! What's the biggest piece of material you can put in it? We have one at uni which will take about a metre square, lots of fun. But for cutting out component pieces its kind of unnecessary having one that big, would be really tempted by something that size if I could get it for a similar price!
I have been after one of these for quite a while. I too am a hacker.
Since you now have one, have you visited www.thingiverse.com ? I have a 3D printer and have used a couple of models from there.
I also want a CNC lathe and CNC milling machine, although lack the space to even get manual versions. I did price up laser cutters and prices them around £4900 from a UK company. Not capable of cutting metals, but even came with a C axis for engraving circular objects. But I again, lack the funds and the space (currently anyway!)
If I ever need anything done, I may give you a shout . . . .
Buy one of these...
Reenact this...
And post us the video :)
(it was the first thing that came to mind)
Already been done by someone, check the link: http://www.synthfool.com/laser/expect_me_to_talk.mp4
can you use it to etch acrylic, say you had a 10mm thick piece of acrylic could you etch the back of it so that it was visble but not all the way through?
Tom.
excellent stuff , im having a problem with the waterjet at the moment in that the very small carbon fiber stuff im doing is getting blasted into the tank ,tried a metal mesh under the wood but it disturbs the jet (on metal stuff you can but a tab on the part then grind it off).
anyway was doing 6 inch steel last night but the things so noisy:).
using alpahcam btw
After 2 days of debugging, I have it working directly from CorelDraw, as if it was a printer. It detects different coloured lines and lets you set speeds and powers etc. It will also engrave vectors and bitmaps!
How hard was that to get working? did it not come with any software at all?
also, awesome :cool:
