- 9 May 2010
- sheffield
dont worry aout it,, people on here are very helpful! and will guid you through it
and its okay i would definitely change the mobo i specced for stulids changed versionNo i think that's a horrible spec and totally overpriced (just my opinion)
Take the graphics card for example i would easily take this card at this price over the asus
I have a list as long as my arm as to the reasons why but have a look yourself and maybe you can see why. http://www.overclockers.co.uk/showproduct.php?prodid=GX-128-MS&groupid=701&catid=56&subcat=1752
Only one more thing you may wanna upgrade to 6 or 8 gig RAM if you can push budget up would run witcher better
Does it flash into a 6970?
4gb is plenty for gaming, unless you wanna be doing a few other things in the background. Upgrade with another 2 sticks later if you really need it in my opinion.
