Under the gpu section you will see a number of performance flags you can see as well as other useful stats.I asked numerous question, yes, alao what do i do once im in hwinfo64
Well the benchmark was a horrible result, and with game performance it has been anything flashy to say the least, decent fps but not the result i should be seeing, should i ddu and bios flash it?
I have a corsair RMx 750 which is more than enough, and yes the clock does move while in bench/games, tho it does not move in gpu-z uet it moves in afterburner....
Perhaps the problem is in the software itself, through which the testing takes place. I thought about that too.On MSI afterburner. Click the detach button at the bottom. Then make the window monitoring graphs big enough that you can see them all.
Then run the test again. After its been running a while (basically just before the end) take a screenshot of the traces of the above graph windows.
We need to see GPU clock speed, GPU temps, GPU usage, cpu clock speeds, cpu temps, memory usage, power usage etc.
You should then be able to see what's limiting you on your card or if you have a much bigger problem....
Unrelated to the above... Did you buy this brand new or second hand?
And have you tried any other benchmark/game for performance against what your card should get?
