Is it worth getting a set of foam tips? I notice some are quite expensive.
Also, anyone use spinfit? Better than stock tips?
this hobby is very subjective.
Hexa is reviewing well.I'm thinking of picking up a new pair in the £100 price range. Not sure which to go with though. I'd like something which has decent bass but not overpowering.
Thank you. I guess I'll order them next week in that case.Hexa is reviewing well.
Truthear Hexa REVIEW! Easiest 5-stars ever
Let's not beat around the bush: I like the Truthear Hexa. A lot. But just how good is it? I spent the last week living with the Hexa to find out.See the freq...www.youtube.com
The version 2 of those look interesting.I can def recommend KZ ZS10 Pro too...
They're actually designed for musicians. It's quite common for someone in a band not to want to hear everything on stage the same way an audience would. They may for instance want more bass or kick drums to help them keep time, they might even want to do without the backing vocals of some thing they don't really nee. Often their monitor mix won't have processing like compression or reverb.Forgive my ignorance but is this (IEM) a different category of product to in ear headphones and if so what is the distinguishing feature(s)?
This is largely accurate, but as a point of interest, it's more about hearing protection as an alternative to ear plugs, plus with the added benefit that you can reduce on-stage levels, feedback and clutter by having fewer speakers around. They're also often combined with wireless beltpacks to allow singers in particular to move around freely without the problem of needing to stay in range of a fixed-position floor wedgeThey're actually designed for musicians. It's quite common for someone in a band not to want to hear everything on stage the same way an audience would. They may for instance want more bass or kick drums to help them keep time, they might even want to do without the backing vocals of some thing they don't really nee. Often their monitor mix won't have processing like compression or reverb.
Some bands will even have control of their own monitor mix via phone or tablet.
Often if your at a gig or festival you will see mics pointing at the audience, it's often so the performs can here the crowd in their IEMs.
the hexa has weak bass and is a quite a flat sounding curve.Thank you. I guess I'll order them next week in that case.
for bass the truthear nova is bass heavy but a little over the £100 budget.
otherwise the thruthear crinicle red are a nice sound with a bass boost adapter included for around £50
in all honesty as long as the tips have a good seal i think most iems will provide solid enough bass, i just felt the hexa to be quite flat overall.
tips you can only know by trying them out. depends on your ear canal shape.I am looking for different tips. Some are so expensive!!! I want to try some foam ones too...
I've had my eyes on them for a couple of weeks now. How much did you pay?Moondrop X Crinacle DUSK yeah!
On first impressions I like these a lot. Clean with attention to the micro details, texture and contrast. With impactful, well extended bass thanks to the dual dynamic drivers.
I did like the Hype 4 but they were a bit too bassy and glossed over the nuances. Instruments and fine texture were less realistic or smoothed over.
