Oh she hates it with a passion
Pretty envious because of the resolution and the utlrawide display wow factor! Jokes aside, we both noticed that colour presentation of this panel is pretty good for gaming standards, definitely no worse than any of the other VA, TN or IPS panel out there meant for gamers. For her the curved display is just no-go, makes all sorts of Lightroom vertical/horizontal adjustments unreliable. Also Adobe RGB gamut on her IPS panel really makes such a difference especially when working with shades of green or blue. Next reason why she'd not be able to use a monitor such as mine is that her monitor has a built in ICC colour profiling which is crazy when you think about it, as it allows you to write ICC profile directly into the monitor rather than Windows, so with some exceptions you bypass all custom ICCs used by software.
Then again, her 24'' Eizo monitor costed more than twice as much as iiyama GB3466WQSU-B1 so there you go.
