And the perfect height for Midge![]()
Fopaux on my side. At least it hits me in the chest as opposed to the old one which nearly garrotted me!
I have been there too many times![]()
Living it large with this feast
Maybe you can make a learning list?Now gotta learn how not to crash it !![]()
works now..Maybe you can make a learning list?
Fine balance between making it low enough for the wife so that putting washing out isn't just a "me" task because she can't reach.
The fix i think is to swap the retractable unit and the hook on the other side which is much higher. It's currently fixed through a fence to create a V shaped line which is left up all the time. If i move to hook to the wall here, then i can just unclip it to make access easier.
£5 thermometer...not sure why it needs to be wifi enabled but at least the clock will always be correct. It does come with an app that I can set up alert if the temperature/humidity goes above or below a certain threshold.
Bring on the zombie apocalypse!
Also can be used for weeding..
Ive been looking for a pair of these where from?£5 thermometer...not sure why it needs to be wifi enabled but at least the clock will always be correct. It does come with an app that I can set up alert if the temperature/humidity goes above or below a certain threshold.
I only paid £5.45, price goes up and down.
Tuya WIFI Temperature Humidity Sensor Hygrometer Thermometer Smart Home Backlight Smart Life Support Alexa Google Assistant
1.76ï¿¡ 80% OFF|Tuya WIFI Temperature Humidity Sensor Hygrometer Thermometer Smart Home Backlight Smart Life Support Alexa Google Assistant| | - AliExpress
Smarter Shopping, Better Living! Aliexpress.coma.aliexpress.com
Did look at them, but ended up with a decent deal on the Tapo thermostats that monitor temps and can be tied into Alexa etc.
Good price though.
